If you are new to the game or returning after a long break, here is a quick guide on how to experience it to the fullest.
What Makes the Gameplay Special?At its core, the game is an endless-runner/platformer set inside a series of floating tunnels in outer space. You control a small alien sprinting forward along the path.
What makes it unique compared to typical 2D runners is its gravity-shifting mechanic. Whenever you run into a side wall, the entire tunnel rotates, turning that wall into the new floor. This dynamic lets you carve out your own path through treacherous levels filled with missing tiles, crumbling floors, and sudden obstacles.
The controls are simple and intuitive:
- Arrow keys or A/D to steer left and right.
- Spacebar or Up Arrow to jump.
Modes and Character ProgressionTo get the most out of Run 3, it helps to explore the different ways you can play:
- Explore Mode: This is the primary campaign. It features a galaxy map where each level leads to new paths, cutscenes, and unlockable areas. It provides a steady sense of progression.
- Infinite Mode: Perfect for when you just want to zone out and test how far you can go. You can collect power cells along the way to unlock new characters.
A Few Tips for a Smooth Run
- Look ahead, not down: It is easy to focus on your character's feet, but you will react much faster if your eyes stay fixed on the obstacles appearing near the horizon.
- Use wall rotation intentionally: If a gap in front of you looks too wide, look at the adjacent walls. Often, a quick step to the left or right can turn a dangerous pit into safe ground.
- Feather your jump: Tapping the jump key results in a short hop, while holding it makes you jump higher and farther. Mastering this difference is key to clearing crumbling tiles without overshooting your landing.
Final ThoughtsSimple games with fluid mechanics never really go out of style. Whether you are aiming to beat the entire campaign or just want to beat your personal best in Infinite Mode during a 10-minute coffee break, it delivers a genuinely fun, stress-free challenge. Fire it up, pick your favorite alien, and see how far you can run!
