je voulais poser une question : quelle est la dernière version d’Autocom, 2021.11 ou 2021.23 ? Merci.
autocom version
- David93
- Boblebricolo
Re: autocom version
Vous avez du mal lire ce n'est pas 2021.23 mais 2020.23David93 a écrit : lun. janv. 12, 2026 3:35 pm Bonjour à tous,
- OliviaRowe
Re: autocom version
Interesting question about the Autocom versions! I'm not an expert, but I've seen some discussions suggesting that 2021.23 might be a more recent release, though support and compatibility can vary depending on your specific device and software setup. It's a bit like choosing the right gear for a downhill run in Snow Rider 3D - gotta make sure everything's compatible for a smooth experience! Hopefully, someone with definitive knowledge can chime in with a more accurate answer for you.
- Boblebricolo
Re: autocom version
Express yourself in FrenchOliviaRowe a écrit : mer. mars 25, 2026 10:59 am Interesting question about the Autocom versions! I'm not an expert, but I've seen some discussions suggesting that 2021.23 might be a more recent release, though support and compatibility can vary depending on your specific device and software setup. It's a bit like choosing the right gear for a downhill run in Snow Rider 3D - gotta make sure everything's compatible for a smooth experience! Hopefully, someone with definitive knowledge can chime in with a more accurate answer for you.
Re: autocom version
Bonjour, pour moi la dernière est la 2021.11.Bonne soirée.
