hi
Can someone help me with this fault code 0528.(starter does not turn crank) with key
code 9528 - 'Absence of command of the starter
But if I bypass the starter relay, the car fires up, I have bought a new relay, but not
have much no have much luck any one can someone help with wire ring diagram or any ideas please
this are the fault codes
1.0528 Fault: Absence Of Command Of The Starter
2.0567 Service Battery Voltage Fault
3.0006 Fault In The Transmission Of The Main Triggering Status On The I/S (Intersystems) CAN
4.0012 Fault Built-in Systems Interface Mute On Intersystems CAN
5.0015 Fault: No Communication With Engine ECU
6.0047 Fault Absence Of Communication With The Electric Power Steering ECU
Thanks in advance for your time.
2015 DS3 1.2 not turning. Fault code 0528.(starter does not turn crank)
- malawiboy1
