diagbox9.149
carfix
diagbox9.149
Message par carfix »
After using Diagbox 9.149 for a period of time, I found that when it reads the data stream (parameter measurement), there are errors in the real-time data stream, and the engine speed may not be displayed or be below normal (above normal). I've tried several different models (Peugeot Citroen DS) and it's all the same mistake! Expect the team to correct it as much as possible in the next update!
In addition, I found on the internet that Diagbox will have a battery voltage detection function display in China? And since the 9. 121 release? And it is said that the 9.152 version has already been released?
