Diagbox 9.146 / 9.143 / 9.129 / 9.96 Activation
Verrouillé
Avatar du membre
Réputation : 1094
PSA-DIAG TOOLBOX
Installation and Activation for Diabgox 9.143 / 9.129 / 9.96
[Vous devez vous connecter pour voir ce contenu] [Vous devez vous connecter pour voir ce contenu] [Vous devez vous connecter pour voir ce contenu] [Vous devez vous connecter pour voir ce contenu]
ENGLISH :
[AFFICHER LE SPOILER (TEXTE CACHÉ]
Licence is FREE FOR THE MOMENT
SAME LICENSE FOR 9.96 and 9.129 / 9.143 / 9.146 FROM PSADIAG
LICENSE NOT COMPATIBLE WITH MR RORRY OR TURBODIAG VERSIONS.
!! WARNING PLEASE READ CAREFULLY  !!
LICENSE IS FOR 1 COMPUTER AND 1 OPERATING SYSTEM.
PLEASE DON'T CHANGE HARDWARE (MOTHERBOARD/HARD DRIVE) OR REINSTALL WINDOWS OR LICENSE WILL NOT WORK ANYMORE BECAUSE ID WILL CHANGE
NEWS :
2022/03/18 - Version 9.96 available (activation is THE SAME as 9.129)
2022/04/01 - Version 9.125
2022/04/10 - Update 9.126 available
2022/04/14 - Update 9.128 available
2022/04/19 - Version 9.129 available
2022/10/31 - Version 9.143 available
2022/11/04 - Licence now free with PSA-DIAG TOOLBOX
2022/12/04 - Diagbox 9.146 available
Information :
The version allows the diagnosis of all PSA cars until date of release and OPEL 2022 models built by psa .
The coding / configuration of options possible offline for 2015 and before cars.
For cars after 2015 in exceptional cases only: dpf, RGE, adblue, keys, VIN code, ... .
If have error message "Erreur de chargement"  if you try any coding you have to DISCONNECT INTERNET BEFORE LAUNCH DIAGBOX to do MANUAL CODING only .
PC Config Requierements and Hardware :
- you need FULL CHIP XS EVOLUTION VCI SERIAL 921815C clone or Original to work. Don't buy if you have LITE version 963830B or 921815B serial or it will not work...no support for lite version will be given for this release.
Link to buy one recommanded VCI choose FULL CHIP :
Download PSA-DIAG Download TOOL :
PSA DIAG TOOLBOX.txt
NEW Video installation : in progress
Installation tutorial :
- Download PSA-DIAG TOOLBOX verify that your configuration is OK on home screen, and then install Diagbox . Just easy as this !
- Now, Verify that diagbox launch and give the "diagdata.db not found" or "licence not valid" message  .
If your firewall is not disabled please ALLOW ALL THE FIREWALL ASKING MESSAGES, IT SHOULD HAVE MORE THAN 10 MESSAGES.
- IT'S FREE BUT PLEASE YOU CAN EVEN MAKE A DONATION PLEASE AFTER RECEIVE YOUR KEY FOR SUPPORT US ON THE LINK IN KEY REQUEST FORM
- GO TO THE LICENCE KEY ASKING TAB TO ASK FOR YOUR FREE KEY ON THE PSA DIAG TOOLBOX FORM .
IF HWID NOT SHOWING COPY IT GetHWID.exe software
PLEASE DON'T ASK FOR LICENCE ON THIS THREAD I WILL NOT REPLY LICENSES REQUESTS HERE !
>> Licence Process is Automated so you will receive it by email <<
- Launch the Zip file received and let it extract on C:\AWROOT folder
- Disconnect internet before launch Diagbox to avoid errors and NEVER do updates directly in Diagbox.. Use PSA DIAG TOOLBOX TO CHECK UPDATES AVAILABLE.
- Let us a comment here if all is okay for you or if you have any question
IF YOU HAVE A "CONFIGURATION ERROR PLEASE RELAUNCH" at start , your pc is too slow .
Please run this fix : [Vous devez vous connecter pour voir ce contenu] and relaunch diagbox it should work.
big thanks to all psadiag team
La licence est GRATUITE POUR LE MOMENT
MÊME LICENCE POUR 9.96 / 9.129  / 9.143 / 9.146 PSADIAG
LICENCE NON COMPATIBLE AVEC LES VERSIONS MR RORRY OU TURBODIAG.
!! AVERTISSEMENT A LIRE ATTENTIVEMENT !! :
LA LICENCE GRATUITE EST OFFERTE POUR 1 ORDINATEUR ET 1 SYSTÈME D'EXPLOITATION.
NE CHANGEZ PAS DE MATERIEL (CARTE MERE/DISQUE DUR) OU NE REINSTALLEZ PAS WINDOWS OU LA LICENCE NE FONCTIONNERA PLUS CAR L'IDENTITE CHANGERA.
VOUS NE POURREZ PAS REFAIRE DE DEMANDE DE LICENCE UNE FOIS FAITE.
ACTUALITES :
2022/03/18 - Version 9.96 disponible (l'activation est la même que pour la 9.129)
2022/04/10 - Mise à jour 9.126 disponible
2022/04/14 - Mise à jour 9.128 disponible
2022/04/19 - Version 9.129 disponible
2022/10/31 - Version 9.143 disponible
2022/11/04 - Licence désormais gratuite avec PSA-DIAG TOOLBOX
2022/12/04 - Version 9.146 disponible
Informations :
La version permet le diagnostic de toutes les voitures PSA jusqu'à la date de sortie  et des modèles OPEL 2022 construits par psa .
Le codage / configuration des options possible hors ligne pour les voitures 2015 et avant.
Pour les voitures après 2015 dans des cas exceptionnels seulement : dpf, RGE, adblue, clés, code VIN, ... .
Si vous avez le message d'erreur "Erreur de chargement" si vous essayez n'importe quel codage vous devez DÉCONNECTER L'INTERNET AVANT DE LANCER LE DIAGBOX pour faire le CODAGE MANUEL seulement.
Configuration PC requise et matériel :
- Vous avez besoin du clone FULL CHIP XS EVOLUTION VCI SERIAL 921815C ou de l'original pour fonctionner. N'achetez pas si vous avez la version LITE 963830B ou 921815B série ou il ne fonctionnera pas... aucun support pour la version Lite sera donné pour cette version.
Lien pour acheter une VCI recommandé choisir FULL CHIP :
Télécharger PSA-DIAG Download TOOL :
Vidéo d'installation : en cours
Tutoriel d'installation :
- Télécharger PSA-DIAG TOOLBOX vérifier que votre configuration est OK sur l'écran d'accueil, puis installer Diagbox .
C'est aussi simple que cela !
- Maintenant, vérifiez que Diagbox se lance et ne donne que le message "diagdata.db not found" ou "licence not valid" .
Si votre pare-feu n'est pas désactivé, autorisez tous les messages de demande du pare-feu, il devrait y avoir plus de 10 messages.
- C'EST GRATUIT MAIS VOUS POUVEZ TOUT DE MÊME FAIRE UN DON S'IL VOUS PLAÎT APRÈS AVOIR REÇU VOTRE CLÉ POUR NOUS SOUTENIR SUR LE LIEN DANS LE FORMULAIRE DE DEMANDE DE CLÉ
- ALLEZ DANS L'ONGLET DEMANDE DE CLÉ DE LICENCE POUR DEMANDER VOTRE CLÉ GRATUITE SUR LE FORMULAIRE PSA DIAG TOOLBOX .
Si le HWID ne s'affiche pas, copiez-le depuis le logiciel C:\INSTALLGetHWID.exe.
S'IL VOUS PLAÎT, NE DEMANDEZ PAS DE LICENCE SUR CE SUJET, JE NE RÉPONDRAI PAS AUX DEMANDES DE LICENCES ICI !
>> La generation de licence est automatique vous la recevrez au mail indique sur votre demande <<
- Lancer le fichier executable reçu et laissez le s'extraire sur C:\AWROOT.
- Déconnectez internet avant de lancer Diagbox pour éviter les erreurs et ne faites JAMAIS de mises à jour directement dans Diagbox.... Utilisez PSA DIAG TOOLBOX POUR VÉRIFIER LES MISES À JOUR DISPONIBLES.
- Laissez-nous un commentaire ici si tout va bien pour vous ou si vous avez des questions.
SI VOUS AVEZ UNE ERREUR "CONFIGURATION ERROR PLEASE RELAUNCH" au démarrage, votre pc est trop lent.
Exécutez ce correctif : [Vous devez vous connecter pour voir ce contenu] et relancez diagbox, cela devrait fonctionner.
grand merci à toute l'équipe psadiag
Avatar du membre
Funay
Réputation : 3
Re: [VIP] Diabgox 9.125 - Install & Activation FREE
Message par Funay »
Du lourd ! Je vais test ça pour les potos.
Merci pour le travail.
Avatar du membre
Nfgrf
Réputation : 0
Message par Nfgrf »
hello, what is the password for the link
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 1:40 am hello, what is the password for the link
Avatar du membre
Nfgrf
Réputation : 0
Message par Nfgrf »
hello, thanks, my  ID: BQ6VBJ9HJB8FNF7GWE7VMNXMVNYDKP25W23UFF7JZN75YG37GCXMXKK4VN5LPP7CXL4CBRKWCRK7
Thanks
Avatar du membre
p2usi
Réputation : 1
Message par p2usi »
Du lourd hâte de pouvoir l essayer
Merci pour ton énorme travail
FLQKYWQHBJXE7GNTCUPBEFSUCSJKMFAVB2JNZYEM5VJT4VSPDTLPBHNSVXJXYFQ5MJPB3YEL4MMF6GYUTMNE2YC6D3
Modifié en dernier par p2usi le ven. avr. 08, 2022 12:31 pm, modifié 1 fois.
Avatar du membre
krouger
Réputation : 0
Message par krouger »
bonjour, merci pour ce que vous faites,
pouvez vous m'activer l'ID suivante stp:
B55UN3DYMEQJ2BXWL5DTPT6XL8VJKFTFS7M3KBMY66VZKKFW2PDLLFFHL5LEMJ5EJPMNPXKW4VVCGE3WCPB7
Avatar du membre
Arthur627
Réputation : 0
Message par Arthur627 »
une activation possible pour l'ID suivant svp ?
BBMUNFD8BVR6YTBE2VDCQK6WQND3F7UVGW5KLF3WJ7M3K75HWVBYNXFWQ4LLGPPEU6DPNPXELPDBGTXXGYK7
Merci à vous
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 10:02 am bonjour, merci pour ce que vous faites,
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 12:02 pm Bonjour,
Merci à vous
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 3:30 am hello, thanks, my  ID: BQ6VBJ9HJB8FNF7GWE7VMNXMVNYDKP25W23UFF7JZN75YG37GCXMXKK4VN5LPP7CXL4CBRKWCRK7
Thanks
sorry ID not working / not valid
Avatar du membre
Nfgrf
Réputation : 0
Message par Nfgrf »
Sorry try now thanks : BQ6VBJ9HJB8FNF7GWE7VMNXMVNYDKP25W23UFF7JZN75YG37GCXMXKK4VN5LPP7CXL4CBRKWFCRK7
Avatar du membre
Mika21
Réputation : 0
Message par Mika21 »
Pouvez vous SVP m'activer l'ID suivante : ET7ZLT5Z6EUQA54PLBAYGW4GNTYYSW4JPK3VUTD3QTKYGNLKP77EY2MFKPJHU3UP
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 12:33 pm Sorry try now thanks : BQ6VBJ9HJB8FNF7GWE7VMNXMVNYDKP25W23UFF7JZN75YG37GCXMXKK4VN5LPP7CXL4CBRKWFCRK7
this time is ok
Avatar du membre
Réputation : 1094
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 12:51 pm Bonjour,
Avatar du membre
Noursy
Réputation : 0
Message par Noursy »
Bonjour à tous, quelqu'un a déjà fait un test avec Windows 11 ? Des retours ? Car c'est indiqué "non testé"
Avatar du membre
leuz18
Réputation : 0
Message par leuz18 »
BONJOUR JAI FAIT UN DON JE PEUX AVOIR LINSTALLATION COMPLETE DE DIAGBOX 9.125 PLUS GENERATEUR DE LICENCE MERCI
Avatar du membre
Funay
Réputation : 3
Message par Funay »
[Vous devez vous connecter pour voir ce contenu] a écrit : [Vous devez vous connecter pour voir ce contenu]ven. avr. 01, 2022 2:04 pm BONJOUR JAI FAIT UN DON JE PEUX AVOIR LINSTALLATION COMPLETE DE DIAGBOX 9.125 PLUS GENERATEUR DE LICENCE MERCI
Déjà on évite de tout taper en MAJ, pas très agréable a lire.
Ensuite, le don te permet uniquement d'avoir une licence et pas le KEYGEN.
Avatar du membre
leuz18
Réputation : 0
COMMENT FAIRE POUR AVOIR LA LICENCE?
Avatar du membre
kokireg
Réputation : 0
Message par kokireg »
suite à l'installation de la version 9.125
serait-il possible d'avoir une clé d'activation ?
voici mon ID :
BLVUPXD2WKZWCBVEJWVJKBKG45MEKBFU86UQPW2GG65MJJ3GWYUJQAZWCS3MNPWGEVVVLTWDUPKXKPNECQB7
Avatar du membre
leuz18
Réputation : 0
j'attend votre retour merci?
Avatar du membre
leuz18
Réputation : 0
Bonjour. Merci de m'activer l'ID suivant SVP :
BM5UPXDVD2YG3PJW8TCDJX6Y45LCRK2XSXUSPE2XC6CZHFFZAVDKN7BXU8MUJK3W66VNJTNEGS5UP3SZWXK7
Avatar du membre
Yellow
Réputation : 2
Message par Yellow »
J'ai fait la mise à jour selon la vidéo. Je voulais faire des diagnostics Citroen C5 et cela me montre quelque chose comme sur la photo. Et maintenant?
Avatar du membre
Pierre62420
Réputation : 0
Message par Pierre62420 »
: HBQKVWQPVY5N3VLSUEKN3GGYDLHBWES5VKNKEDSV5SGSXZUTCMQPDZQN4RNTUHWNKXQKCZWSU4MF6WQ3CEQFHWJ5L3
Merci pour ton travail Mike! :)
Avatar du membre
mendes38
Réputation : 0
Re: Diagbox 9.125 (03.2022) - Free update for Diagbox 9.96 (PSADIAG or JTR versions)
Message par mendes38 »
salut pourrais tu me faire l'activation de cet ID stp ?
BKMUNFD44KXRAXSWUTCWPBJVEL4YK7EZEPKTQBNYC4CQJXNW4UVLJ64YQ6LURKVZEQMHLKJW444KLTHFUQB7
Avatar du membre
bigmaluco
Réputation : -1
Message par bigmaluco »
Bonjour. Merci de m'activer l'ID suivant SVP : FRQKYWRXJGN34XCV4EJPCVSUCRP7HCYXD4GW6GN6VKP3KYENTZJ7EDN237
Cest l'id que j'ai obtenu après l'installation de la version 9.96
Avatar du membre
Karl
Réputation : 0
Message par Karl »
  Bonjour. Merci de m'activer l'ID suivant SVP:
  BQ6VBJ8PS3V3SF7GWE7VML7MDQYV4RBEENYBVJPPGQ3DTNPMFWTU4GB6YL3UBQ23W84LCRBZWCRK7
Modifié en dernier par Karl le ven. avr. 01, 2022 9:09 pm, modifié 1 fois.
Avatar du membre
gsxr1000full
Réputation : 0
Message par gsxr1000full »
Bonjour. Merci de m'activer l'ID suivant EN82CJ8TUWYCQJTCY2WDQPTNDG6CQJ3XFSVVDQ7VGYYLHGPBWWW5PKB2GCSMNHFXHS34EK7FFCRK7
merci beaucoup et bon courage pour tout le travail
Avatar du membre
jeromePSA35
Réputation : 0
Message par jeromePSA35 »
bonjour demande d'activation 9.96  merci
BKMUNFDYFBYBV7SWUTCWPBUG245YLP6XS7BWQJ2WY4DXHF3C8P5ZQ3AWQ7KMHE5WNV5LGPGYWQMRG37HJUK7
Avatar du membre
Vishnu
Réputation : 0
Message par Vishnu »
Bonjour, suite à mes déboires ( cf conversation avec Mike) pour avoir installé une MAJ virtual box, j'ai dû tout re installer la diagbox sous VM (ok maintenant) et la diagbox native.. mais j'i un nouvel IDENT et j'ai donc besoin d'une nouvelle licence. mon ident apres l installation :
B2MUN7DVN7Y5GN4WETCMGKLDC7CBJTYXAWDEG3FDL5VUJKPEQPUFQKLEQL5VNF7E2SVMQ7MXU5TWKFMVE737
merci...
Avatar du membre
weldem97
Réputation : 0
Message par weldem97 »
: AFDUP7D4J2GL7TMEQ3CBLFDDETLSQPMGNVUJHBWDU4BMMF3DEPDHJ7MCY3KVNXGWQ7VWLTWFANLLJ3ZYQPB7
merci pour ton travail mike
Avatar du membre
polux1314
Réputation : 0
Message par polux1314 »
bonjours pouvez vous m' activer svp pour la 9.96 l ID suivante ARDUNTD2NJC4E24EQP43GBUFNUTUG7NY63VJPXVZJ64MMF3XCRK7
 merci pour tout ton travail Mike
Avatar du membre
Duratec77
Réputation : 1
Message par Duratec77 »
☺️☺️ très bien psa-diag
Avatar du membre
Duratec77
Réputation : 1
Salut a tous qui peut me renseigner ? J’ai un autre ordi en intel celeron 4g de ram et 2.85 utilisable ma question est pourra t’il accepter le diagbox 9.125 je pose cette question parce qu’il n’accepte pas les machines virtuelles merci pour vos réponses la team
Avatar du membre
sergio99
Réputation : 0
Message par sergio99 »
FNQKYWQ97QCAWY6VDLPBUEJT4VLBYHETDQP3EU8T5KRB6YW8DCMKVU8YDXP77G62MZQTWYU7CMKPJEJT5PRF3FW8DU
Avatar du membre
yonee77
Réputation : 2
Message par yonee77 »
QC6VHJ897EM2TGXBEJU3ULXDYLQLTK7NGSUM3KTHG4PVWL3HWUYVJGBSUYUMXKE6C86MXLFLFCRK7
Avatar du membre
andre
Réputation : 0
Message par andre »
peux  tu m'activer l''id  suivant ;E73GJT5APHCRWX4BLK4WNXKVKE2W4WMYNX6WC252PKNYQ65YKFCGEYURPXDCYQDK
merci:
Avatar du membre
diagautoecu
Réputation : 0
Message par diagautoecu »
voici mon ID et Merci pour votre travail.
BKMUNFD44KXRAXSWUTCWPBMG4SLFPBCYEXLRN3AWG7LJMB4XJPVLNTWE2U3TQ35GLN5XL7MZEPTXKXUWSYK7
Avatar du membre
ceciliadubled42
Réputation : 0
Message par ceciliadubled42 »
Bonjour quelle difference entre diagbox 9.96 et 9.125 car si pas de changement majeur je ne sais pas si je vais l installer cela depend de vos reponses svp merci
En tout cas un gros merci a l equipe de [Vous devez vous connecter pour voir ce contenu]
Avatar du membre
Matth92
Réputation : 0
Message par Matth92 »
Bonjour. Merci de m'activer l'ID suivant SVP: EUQKVER48UXXXWSTDPHE6YUNMQLFTEYYDYQPXVNXVYQ26VGW5UNPDUYWCZL3NWGVMLQBSZG3MBKKBDUNK2RFNWJ6DH
Verrouillé
